Systems_Engineer
I am making this thread to share my build progression with anyone interested. This is my 22” Power Wagon Stock:
Modifications Completed:
- Removed the side "RAM", "HEMI", and tailgate dealership decals
- Recon smoked cab lights (amber)
gorecon.com
NOTE - These cab lights are for trucks with EXISTING cab lights, for trucks that do not have existing cab lights, look up Recon Part #264146Y
- Replaced stock silver "RAM" grill insert for black "RAM"
- Installed Rims & Tires
Rims - Black Rhino Arsenal 17" x 9.5" -18mm Offset
www.blackrhinowheels.com
Tires - Nexen Rodian RM7 MTX 35" x 12.5"
*Note: With my tire size and rim offset, the tire sticks out "just a little bit" from the OEM wheel well fenders. I do get a very small amount of rubbing fully turned in reverse on the driver side door. It rubs on the corner frame molding in the wheel well and that is it. You can remove this, or grind it down with a dremel.
Up to date image of the build with everything above installed:
Modification parts en-route:
-Recon smoked third brake light (On back order ~8 weeks)
gorecon.com
Future Mods / Feedback Requests / Recommendations:
-12” Uconnect 5 screen & Bezel (Found)
www.moparwarehousedirect.com
-Bed utility Rack
(See the power wagon picture featured on black rhino's website. I am looking for a bed rack similar to what is pictured, without the pop-up camper)
-Exhaust recommendations
-Air intake recommendations
-Tuner recommendations
-General aftermarket parts you’ve found to be really cool or that you would recommend!
Dodge RAM Heavy-Duty 2500/3500 03-18 5 Piece Set Cab Roof Lights LED Smoked Lens in Amber - RECON Truck Accessories
Shop Dodge heavy duty 2500/3500 5-pc. set smoked cab roof light lens w/ amber LEDs complete kit. We offer unique aftermarket truck lights & accessories.
Arsenal Truck Rims by Black Rhino
The Arsenal truck wheels by Black Rhino. Explore our selection of aftermarket truck rims designed to precisely fit your vehicle.
Dodge 19-21 RAM 1500 Red LED 3rd Brake Light Kit with White LED Cargo Lights and Smoked Lens - RECON Truck Accessories
Dodge 19-21 RAM 1500 - ULTRA HIGH POWER Red LED 3rd Brake Light Kit w/ ULTRA HIGH POWER CREE XML White LED Cargo Lights - Smoked Lens
OEM Mopar Parts | Mopar Warehouse Direct
Your GM won't stand out with aftermarket products. The only way to keep winning is to use genuine OEM parts from Mopar parts Direct.
-Bed utility Rack
