I’m sure they will take care of you regardless of time. Ive been going back and forth since December. Purchased Black Friday. I had one on my 2011 F150. Couldn’t have been happier with it. I want this one to work. But…I hate hearing this. I’m in process Of installing mine now. I screwed up and installed the rail seals on the outside instead of inside. You guys are right, their customer service is great. They immediately sent me some new seals. They arrived a few days ago, but I was headed out of town. I got them out to install today and it was the wrong seals. Dang it. Now, mind you, all this is my fault for screwing up the original seals. The only thing that sucks is, I leave on Thursday this week, to go to work overseas. Will be gone for 30 days. I probably won’t get the seals in time to install the cover and see if there’s an issue with mine.
I think everyone is having QC and staffing issues these days.
2022 Ram SB bed out of spec? Front is 3 inches wider than the back! WTH?
2022 Ram SB bed out of spec? Front is 3 inches wider than the back! ** Bed is not out of spec **
Side to side, between rails for Leer 650 cover Back of box, which makes sense given the cover 60 inches and 7/16 Front of box, what the actual heck? 63 and 3/4 inches I fought and fought and fought some more before I measured and found out WHY I couldn't get the cover to set in there in the...r.tapatalk.com
Maybe this is why we’re having such issues?
automotozine.com
Mine is 63ish at the cabThe bed has been like that since 4th gen. They should know that.
ETA: Actually, I think the HD bed has always been ~65" at the cab and ~62" at the tailgate.
Truck Bed Dimensions & Size Chart Comparison - Automoto Zine
Truck bed size chart! Dimension chart and comparison for Dodge, Toyota, Ford, Nissan, Chevy/GMC pickups since 1996 until 2022.automotozine.com
Id assume they are going by width inside the bed close to the floor of the bed, not the bed rails that would make up the extra 2ish inches they have listedGuess the chart is measuring somewhere else?
Still, they are tapered and have always been tapered since 1st Gen AFAIK. Might be an inch or so different.
Yup they have never had great QCSo I’m back to it being Bakflips fault?
Just installed mine on 22 shortbed and had to re-drill the holes to get a proper fit. Disapointed but it works fine now. The fit and seal isn't near as good as it was on my F150 (was completely waterproof).
I was getting leaking in the rear. Turns out the rubber wasn't touching the tailgate. The cover was too far forward over the bulkhead. I readjusted and pulled it down enough so the front and rear seals were in contact with the truck. So far, so good.Just installed mine on 22 shortbed and had to re-drill the holes to get a proper fit. Disapointed but it works fine now. The fit and seal isn't near as good as it was on my F150 (was completely waterproof).
Can they send you an empty box and call tag?Anyone got any suggestions on where to get a box to send this thing back in???!
I realized yesterday while I was washing my truck I have the same issue. I'm glad to see confirmation that worked because that's what I assumed I would have to do.I was getting leaking in the rear. Turns out the rubber wasn't touching the tailgate. The cover was too far forward over the bulkhead. I readjusted and pulled it down enough so the front and rear seals were in contact with the truck. So far, so good.
