Couldn't agree more. I've been looking at toy haulers lately and have come to the conclusion that it is either going to be a bumper pull or a gooseneck 'horse trailer' garage/living quarters type trailer.While I agree that there are advantages to the 5th wheel platform, I think you're overthinking it a bit.
You can achieve a safe/comfortable level of stability and control with a bumper pull trailer. It may take a little more effort/equipment, but very it's still very doable and safe.
As far as shorter overall length, much of that comes from the section of the trailer that is hanging over the back of the truck. It's not really an apples to apples comparison to a bumper pull in terms of useable living space.
I agree that it doesn't make much sense to prep a truck with limited payload for a 5th wheel.
Unpopular Opinion: People who tow need to stop buying 2500's.
Grits, I will have to do some more searching on "class 2 rating". I think it may have something to do with vehicle weight rating and taxes/registration fees etc etc but will do some homework on what class ratings are and what they really mean.
I consider myself a critical thinker and have wondered about the significantly higher payload rating on a 3500 with the same engine (standard output) and transmission as my 2500. To my knowledge, the only difference is my coil springs compared to their leaf springs. To be fair, coil and leaf are two very different animals... But wouldn't adding airbags in the bump stop location on my truck (in addition to the coil springs already there) provide the same amount of support as leaf springs? Or even (and here's a dangerous thought) possibly provide MORE support than the leaf springs on a 3500 that's equipped with the standard output? I can't speak to the 3500 with the HO and a different transmission (and certainly not comparing it to the DRW) but unless there were differences in tires and axles and brakes on the 3500 with the standard output... Seems like the rear suspension is the only difference between the two trucks. That and a sticker with almost 1000lbs higher payload. I just haven't done the due diligence of finding a 3500 SO and putting eyes on it to compare.
Sent from my Pixel 3a XL using Tapatalk
Not 1000lbs higher, try about twice higher for 3500.... and a sticker with almost 1000lbs higher payload. ...
All things equal, SO will have a higher payload comparing to HO because AISIN transmission is heavier. Rear axle might be slightly heavier too but don't know by how much. My HO Limited has 3840 lbs or something like that. Many 3500 SRW are North of 4000 lbs.Twice as high even for a standard output 3500? I only ask confirmation as I see your name has "HO 3500" in it
Check out a Reese "Goosebox" (not gooseneck) it removes the need for that 300 pound hitch in your bed. We have a similar hitch, and our bed requires only a "ball" in the center.I know I'm a newbie on here and yes I have been search functioning the crap out of this forum. I understand that there are two different camps when it comes to payload and towing with the 2500 diesel: camp number 1 says I'll kill us all and camp number 2 says add aftermarket air bags and #sendit. I'm all about happy mediums so I've yet to choose which of those hills to die on...
I came from a 2015 Charger SRT that was packed with technology and comfort. The birth of my first daughter drove me to shift the mindset to something that was just as comfortable but robust and safe enough to transport my family. My 21 2500 Limited 6.7 with a ranch hand legend bumper absolutely achieves that 110%. Primary mission accomplished.
I'm researching what it would look like to buy our first camper. It's my understanding that a 5th wheel has many benefits over a travel trailer (colloquially referred to as a TT, right?) such as being a more stable towing setup, better turning radius, and a shorter effective overall length when compared to an equivalently sized TT.
In staying aligned to the primary mission of safety for my family, I have been trying to determine a 5th wheel camper and hitch setup that would be within my doorjamb sticker 2063lbs payload capacity and... I don't think it's actually possible.
A b&w or pullrite hitch is going to be an average 300lbs. I'm a 6' 3" fat kid, plus wife and baby and suitcases/baby gear... Realistically I'm looking at a conservative number of 1000lbs. Which would leave me with only 1063lbs... The smallest 5th wheel camper at my local camping world is a Jayco eagle HT 29.5 BHDS. Jayco website says dry hitch weight is 1745lbs... That means with zero fluid in any tanks and zero things packed in this camper the "pin weight" (weight placed upon the 300lbs hitch in my bed, right?) would put my payload a solid 700lbs over what my door sticker says.
So... Even if I leave my wife and child at home, pack nothing in my truck, take the ranch hand bumper off, become less fat... Actually no, I'll go full crazy person on this thought train:
If there were a way to remote control my truck with nobody and nothing in it, and I tried to tow the smallest 5th wheel camper I can locally find (with absolutely nothing inside of it)... I would be about 20lbs away from the door sticker maximum payload.
I realize that I've got the needle turned as far in the conservative direction as possible for this hypothetical scenario, but the conclusion seems to be that it is not possible to tow a 5th wheel camper (even a "HT" model designed for half ton trucks) with my truck without exceeding the maximum advertised payload.
I can't for the life of me understand why Ram would go through the trouble of putting a 5th wheel prep package on a truck that isn't able to actually use it. I may be way off base and missing something here, and any feedback would be graciously received. I appreciate everyone's time and will continue reading and learning from all of you.
I've seen those and I'm holding out on that as a last resort.Check out a Reese "Goosebox" (not gooseneck) it removes the need for that 300 pound hitch in your bed. We have a similar hitch, and our bed requires only a "ball" in the center.
Older 2500s had rear leaf springs, no?I’m coming from a 2000 quad cab longbed 2500 ctd into my new 2500 crew cab shortbed ctd. My old truck never had any problem with my 5th wheel which is approx 8000 gvwr. I had steel toolbox fully loaded in the bed, along with the Curt hitch. Never felt like it was overloaded. Have yet to hook up to the 5er with the new truck but don’t expect any problems. Thoughts???
That is irrelevant my 19 with coils is way better than my 2005 with leaf springs and supper spring helpers was for handling a loadOlder 2500s had rear leaf springs, no?
Wow, you're good! Learned how to Google a bit and have been playing around on the Ram towing guide website. Sure enough, the 3500 SO has a higher payload but lower towing capacity than the 3500 HO.
Huh... So per the Ram website a 3500 Limited SO SRW has a max payload of 3750. And the only physical/mechanical difference between that and my truck is leaf springs vice coil springs. Interesting...
HO will have higher tow rating but not the payload.
