AnthonyD1978
It's actually that transfer of load that caught my eye. Frame-mounted is not my favorite system. 6 feet of surface area and 30+ mounting points to distribute the load are going to be stronger. They sit 3 inches higher so they are also a lot less likely to be used. But it's those 30+ rivets that are turning me off. That's a lot of holes to drill in a 75k truck.
I'll look for the youtube vid. The pics on the website are not very clear.
Thanks!
A proper frame-mounted slider will still use the entire pinch weld to distribute the load since the slider sits below the pinch weld. I looked at the Ellis stuff for my previous truck, but I want a step and a kick out on my slider. I've used the kick out a lot for a step to reach my rack as well as to pivot this boat around rocks.
Also, if you decide to go with the Ellis slider, make sure you take steps to mitigate rust from all those holes you're going to drill....
