Installed Edge CTS3 with EGT probe. I have AMP steps - so I had to split the OBD2. I initially installed the CTS3 without the EGT probe and it worked fine. Now that I have the EGT probe on (via EAS cable), about every 3rd time I start the truck it just hangs with the message of 'loading guages....'. If i unplug and replug the OBD2, it works fine again. PITA.
Anyone have any experience like that?
Also, changed the fuel filters for the first time this weekend. Semi-rant: so the rear filter housing was a b&^% to get off (28mm socket / 1/2 socket wrench). But did it. And I had drained the fuel via the little valve, but I got a nice diesel shower when removing the housing. That's not my biggest gripe: the front filter must have been installed by the Hulk. Would not budge. So i decided to over-power it with an 18v Milwaukee impact driver. I have driven 1/2" lag bolts (6" long) into trees with that impact wrench. But it had nuthin' for the f&*$ing filter housing. I ended up using a breaker bar with an extension to loosen it. WTF? btw: the mopar instructions call for 22 ft/lbs when re-installing. Guessing the original factory install was closer to 122 ft/lbs..... just glad I didn't strip the plastic 'nut' on the housing.
Any wise folks out there with insights (pun intended) on the CTS3 issue and/or not dumping diesel everywhere when removing the rear fuel filter housing?
