I have the same truck and am wondering if you have any desire to put on a leveling kit after you have had it that way for a while. The AEV wheels seem to take care of the backspacing from what I can gather. Do yo have any rubbing at all with full lock or under flex? Thanks!Well so far so good. Fits perfect in my opinion. No rubbing at all. Looks factory!
Zero. Perfect fitment.I have the same truck and am wondering if you have any desire to put on a leveling kit after you have had it that way for a while. The AEV wheels seem to take care of the backspacing from what I can gather. Do yo have any rubbing at all with full lock or under flex? Thanks!
35" Nittos. No lift, no level, and no rub. AEV SNAP to adjust TPMS and tire size.
Which brand?Trucks looks great sir
No rub here on 285/75-18 which are larger in diameter than 35x12.50s by about an inch depending on brand
calibrated with aev procal snap
I have nitto ridge grapplers if that’s what you were asking, sirWhich brand?
Yes, thank you. Just trying to see if I can run 35x12.5 toyo mts which are 13.2 inches wide on +25 offset wheels.I have nitto ridge grapplers if that’s what you were asking, sir
Not the original poster but I have saltas with 35/12.5 tires no lift no level no problemsLooks incredible. Thinking of doing this exact setup. If not too much trouble, you mind posting more pics? Thanks!
I have stock suspension. I have never rubbed in anyway. I don’t off road with my truck so it has never been fully flexed but I do drive a lot of dirt roads with some pretty tight off camber switchbacks and still it hasn’t rubbed. Hope that helps.Looks brilliant. Several people have said it’s been done with no lift and they experience no rubbing. Is this with the truck level? Have you tried it with the front suspension flexed at all? My question would be if one side is untraveled and turned does it rub?
Cheers
Love the setup. No lift ? Specs on tire?Well so far so good. Fits perfect in my opinion. No rubbing at all. Looks factory!
Love that look! Specs are very similar to my innov8 wheelsWell so far so good. Fits perfect in my opinion. No rubbing at all. Looks factory!
