Chris85xlt
I think you have the Progressive and Linear valving the other way around.So looping back in this thread to discuss stock-length upgrade shocks…I’ve been thinking/reading about shocks a bit…
Stock PW shocks (Bilstein) are Digressive (firmer with small displacement, softens with larger displacement). This improves cornering on the road (small displacement) but makes for a relatively stiff/uncomfortable ride over small/medium bumps on the highway, washboard roads. I had Icon shocks, which are also Digressive, on my last truck. It handled really well on the street, tighter than stock, but I was pretty stiff on dirt roads and some speed bumps were brutal.
Fox 2.0 shocks are going to be Progressive. They are going to sacrifice on-road cornering for a smoother ride on washboard roads , and float nicely over small/medium bumps on the highway (think: Raptor). But, be less settled on big bumps offroad such as rock crawling.
Higher end Fox and King will be closer to a Linear valving that should be smooth on road as well as rock crawling.
I think I would like to replace my stock shocks with a Progressive shock, like a Fox 2.0 to get the ride I really desire from this truck. I do some rocky trails/semi-technical wheeling, but I think I would be happier trading some performance there for a smoother, Cadillac ride on the highway and washboard roads. Upgraded bump stops* should help smooth things out offroad where some a Progressive shock might otherwise be a bit harsh.
*i just bought sumo blue for the front, not installed yet… And Will probably get Thuren boogie bumps for the rear.
Does anyone know the extended + compressed lengths of the OEM shocks? I saw a YouTube video where the guy replaced the OEM shocks with Bilstein 5160s, and the shocks for Ram 2500 +2-2.5”F/ +1”R look to be about right…I think maybe be Fox 2.0 for Ram 2500 +0-1.5”F/R shocks might actually fit fine, based on their compressed/extended length compared to the Bilsteins.
Ok that’s enough rambling for now…
Most of the Kings and Fox like the 2.0 etc are Linear where the more expensive Kings and Fox with internal/external bypass are Progressive (like found on Ford Raptors and Toyota Pro's)
Lots of great info on shocks
Digressive vs Linear vs Progressive Pistons & Shock Valving - AccuTune Off-Road
Ryan Raker, the founder and author of this article, has been designing, tuning, and manufacturing shocks with digressive, linear, and progressive damping
