Realized I posted in wrong spot.
Added the Baja fog lamp swap before it heads out to Michigan to AEV.
They sure will. Same part numbers and everything.Unfortunately 2021 OEM lights won’t work with the 2022.
Ah! You're that guy running around with fog lights on all the time with no fog in sight?!?!Yeah, I swapped out the stocks with the BDs on my PW. I went with the SAE version, and they are a little brighter than stocks. I didnt want to do the regular ones because I like to run them all the time and I dont want to be the a-hole running around blinding everyone. At some point, I might swap them for the regular ones, but i suspect you wouldnt want to run those all the time.
I shoulda saved my oem fogs, I think I threw em out you could had em for free.Hey all. I got a Tradesman which didn’t come with fog lights. What are you all using? Thanks.
So, instead of refocusing down to the right (because you already know the brighter lights are coming at you), you’re response is to instantly and unexpectedly blind that person, potentially causing him to lose control and put other drivers in the area in danger?Ah! You're that guy running around with fog lights on all the time with no fog in sight?!?!
I can't stand those people, most of the time I'll blind em with my Baja designs non SAE fogs with a quick blast, or the light bar.
Most of the time... yes.So, instead of refocusing down to the right (because you already know the brighter lights are coming at you), you’re response is to instantly and unexpectedly blind that person, potentially causing him to lose control and put other drivers in the area in danger?
Sounds like you’re more of an idiot, and more dangerous, than the people running the bright lights.Most of the time... yes.
Cool story.Sounds like you’re more of an idiot, and more dangerous, than the people running the bright lights.
I think you're really taking things out of context here, or maybe you just like to argue who knows.Yea, that's a huge D* move there partner.
Do you also chase people down that run yellow lights, don't use their turn signal, or speed and give them the what-for as well?
How about the RAM owners whose fog lights come on in a turn or with a signal? You make them "see the light?"
SMH.
agreed.Can we all just agree that yes I may be an ass and am very hard headed?
