Rockcrawlindude
a rock crawlin’ dude
You look at her face?I found the part online for $11 plus shipping. It's getting replaced. I'd stare at defect like a zit on Jennifer Aniston's face.
Okay... on her butt cheekYou look at her face?
Looks great. Do you by chance have any pics from the side of the truck and close ups showing clearance between the mounting point and rhe tonneau cover?
I wish you lived close enough I could pay you to adjust mine. That high threshold set by RAM is driving me crazy.I use my AEV pro cal, it’s super easy to use.
Some may wonder why I chose 45 psi if I run 55psi. Well, I need to run 49psi to match my gvwr with these tires but the tires I want to get (soon? maybe?) will require only 42psi to carry the same weight (I’ll probably run 45) so I was just future proofing my settings.
Yes but it doesnt have the towing capacity I need. But it is cool . . .That sucks.Hopefully they get it ironed out for you quick. Do you have the Cool-manche for back up?
The pro cal is locked to one vin, sorry dudeI wish you lived close enough I could pay you to adjust mine. That high threshold set by RAM is driving me crazy.
I also wish I could drop my cruise control minimum speed down to at least 15 mph, but 10 mph would be great.
Mud Flaps look pretty goodGot her in the garage this evening to get the mud flaps on, the windows tinted and the hood bug deflector installed. I did get the flaps and tint done, I'll get the hood deflector on tomorrow.
I ordered AVS vent visors on Amazon and today got a set for an old Chevy 2 door regular cab. Well, I'll return this and wait for the correct ones. December 16th is the appointment for the Krown rust proofing job, and I think it's done at that point.![]()
Put a Magnaflow D-fit muffler on my Power Wagon.
Disappointed a bit, its very quiet. Was looking for a deeper rumble, didn't quite get what i wanted.
Stock resonator installed still, haven't taken it off.. heard it makes a little difference in sound quality but the trade off is drone.
I took off my resonator and kept the stock muffler.Put a Magnaflow D-fit muffler on my Power Wagon.
Maybe i'll ditch the resonator too.I took off my resonator and kept the stock muffler.
A little louder and sounds good. You can hear it in the cab when you get on it, but quiet when crusing.
NO DRONE.
I like it.
G003's nice. Update us on the road noise
Lotta landcruiser guys run them. Was just curious how they were on a vehicle that actually uses the load rating.So you can hear them, but not obnoxious by any means. Most noticeable around 30 mph or low speed turns.
Made a pretty noticeable difference in ride. Small bumps are absorbed and train tracks are wayyy less harsh. The noise is well worth the benefits IMO.
Good deal. Let us know inn 10k miles how they're holding up. G015s or x-at will be my next setThey were actually quieter with my trailer hooked up. Tire guys set them at 65 all the way around, but even hooked up to my trailer, the outer lugs are staying cleaner. Will need to drop the pressures a bit to flatten them out.
