Looks great. Do you by chance have any pics from the side of the truck and close ups showing clearance between the mounting point and rhe tonneau cover?
I use my AEV pro cal, it’s super easy to use.
Some may wonder why I chose 45 psi if I run 55psi. Well, I need to run 49psi to match my gvwr with these tires but the tires I want to get (soon? maybe?) will require only 42psi to carry the same weight (I’ll probably run 45) so I was just future proofing my settings.
I wish you lived close enough I could pay you to adjust mine. That high threshold set by RAM is driving me crazy.
I also wish I could drop my cruise control minimum speed down to at least 15 mph, but 10 mph would be great.
Got her in the garage this evening to get the mud flaps on, the windows tinted and the hood bug deflector installed. I did get the flaps and tint done, I'll get the hood deflector on tomorrow.
I ordered AVS vent visors on Amazon and today got a set for an old Chevy 2 door regular cab. Well, I'll return this and wait for the correct ones. December 16th is the appointment for the Krown rust proofing job, and I think it's done at that point.
Mud Flaps look pretty good
Put a Magnaflow D-fit muffler on my Power Wagon.
Disappointed a bit, its very quiet. Was looking for a deeper rumble, didn't quite get what i wanted.
Stock resonator installed still, haven't taken it off.. heard it makes a little difference in sound quality but the trade off is drone.
Darn, had made plans on buying this once the ‘22 Limited Hemi comes in. Guess I’ll go with the Gibson.
I took off my resonator and kept the stock muffler.
A little louder and sounds good. You can hear it in the cab when you get on it, but quiet when crusing.
NO DRONE.
I like it.
G003's nice. Update us on the road noise
So you can hear them, but not obnoxious by any means. Most noticeable around 30 mph or low speed turns.
Made a pretty noticeable difference in ride. Small bumps are absorbed and train tracks are wayyy less harsh. The noise is well worth the benefits IMO.
Lotta landcruiser guys run them. Was just curious how they were on a vehicle that actually uses the load rating.
They were actually quieter with my trailer hooked up. Tire guys set them at 65 all the way around, but even hooked up to my trailer, the outer lugs are staying cleaner. Will need to drop the pressures a bit to flatten them out.
Good deal. Let us know inn 10k miles how they're holding up. G015s or x-at will be my next set
Husky front center seat mat. Almost a perfect fit, maybe if I trimmed less for my floor cubby it would of covered the carpet 100%. But for the open box deal on Amazon I’m happy.
