UglyViking
Did they change the gear ratio for 20+ trucks? 19 trucks had a 4.71 (4.71 x 4.10 = 19.3:1) which is still quite more torque focused than the 68rfe, I grant you.3.23 x 3.73 = 12.0:1
5 x 4.10 = 20.5:1
That said, the torque on the 6.4 starts to reach peak torque around 2600 RPM, (just over 300ft lbs). The cummins hits 480ft lbs around 1000 RPM and peaks around 1600.
torque vs ratio at max tq (first gear)
850ft lbs x 12 = 6960
429ft lbs x 19.3 = 8280
torque vs ratio at low rpm (measured from where I can find dynos starting to draw from)
400ft lbs (at 600 rpm) x 12 = 4800
150ft lbs (at 2k rpm) x 19.3 = 2895
I understand these numbers don't actually mean much by themselves, but my point here is that down low the cummins has a much easier time moving those tires than the 6.4 does.
Before anyone says anything, I'm not gonna sit here and pretend I've got a lick of mechanical eng background, and I've spent no time looking up the formulas for the proper way to measure this (perhaps this is even close to correct?) I'm just trying to make a point based off the RPM differences I'm seeing and my general experience in high revving, short stroke engines vs low revving, long stroke engines.
EDIT: Adjusted max tq number for 19 trucks, assuming the data I had was previous years.
