That's the best part of the Leviton switches. You have so much room for sticky notes on the plastic plate!
Decora or old style?
I really wish you weren’t so far away. I would be interested in both the bumpers, and a guided tour of the switch wiring process.I will have F/R white painted bumper from my truck if anyone is interested when I get the front installed when it shows up mid January.
Sorry about the distance on the bumpers.I really wish you weren’t so far away. I would be interested in both the bumpers, and a guided tour of the switch wiring process.
Have you considered vacationing in DFW? Then you could just drop them off!Sorry about the distance on the bumpers.
I have enough connectors coming in to make 5 sets, they had minimums on the connectors and will be making mine and trying it out and documenting it all for future reference or maybe build some for sale after I know it all works on my truck.
I'm just waiting for parts to show up to get to work on this, mind you I have a Diesel that I will be working on and the switch will not be available till mid February as I'm told. As to getting it to work on a Power Wagon I'm just not sure yet as on our Diesel trucks the exhaust brake have 3 functions off/auto/on and traction control is up with the Hazard button while in that same spot the Power Wagon is the traction control 2 function on/off. I'm guessing it's all controlled in the switch as all the wiring looks to be the same to the switch across all trucks.Following for more info. I have a 2019 Power Wagon and want to add the switches. It looks like most of the parts places don't even have the switch panels listed for the 2019s yet.
Looks like and as you know they aren't cheap either $205 retail, the issue is Ram not having any inventory of them at the moment at least for unit I need.I think I have tracked down the part number for the switch panel I would need. I need to have the tow/haul, traction control, front park sensor and rear park sensor. Just like the image below. Have you tracked down the required terminals and relays?
How about just a sticky note?![]()
I am in the same situation. I ordered some bumpers from Expedition One. I am a big fan of keeping the factory look and not having to go aftermarket. I actually ordered a SPOD Bantam but will be returning it if I can get this to work. I have made a number of wire harnesses and fuse blocks in the past and have most of the tools. I also have a bunch of different type of connectors and terminals (Metri-pack, deutsch, amp, molex, etc)Looks like and as you know they aren't cheap either $205 retail, the issue is Ram not having any inventory of them at the moment at least for unit I need.
I have sourced the parts just waiting for them to show up to begin work on it. I have around 40 hours into this researching wiring diagrams and sourcing parts and making a Solidworks model and print of the wiring base for the wire layout and about $500 in terminals, wiring and crimpers to do my truck at this moment not including a switch panel. If you could take a pic of the wiring that goes into your switch behind the dash panel so I could compare it with the Diesel would be great.
I almost bought a Power Wagon but in the end decided on the diesel after I drove both based on MPG back to back and resale so I'm turning my truck into a Diesel power Power Wagon, Just waiting for the Fab Four winch bumper to come in and that's what got me working on this Aux kit as I did not want to cut up my dash to but in a bunch of switches for lights.
With that said I looked last night and my PW does not have the auxiliary PDC box installed. This makes sense based on your comments on why it is installed on your truck. I am not sure if this is something that can be purchased or not. I am going to do some research. I will take a look at the wiring behind the switches this weekend and report back.
So for an update. I have not had a chance to open my dash and look at the back of my switch bank. Based on the wiring schematics it looks all trucks are the same. I did order a switch bank that came with the switches I need. I just ordered the connectors so that I can connect to the back of the OEM switches. My plan is to wire up an aftermarket Bussmann RTMR relay/fuse panel to the OEM Aux switches. It only has 5 relays which is enough for my needs. Once I verify everything works I will share part numbers.
