Nice Rig! Does the 315/70/R17 equal to a 35" tire? Damn 37" Terra-Grapplers would look really good on the stock 17's, I'm slowly liking that stock black wheels.
Yes 315/70R17 is nearly identical to 35x12.5R17
Well it didn’t take long for me to upgrade again.
Middle Picture: Stock Height, 35x12.50r18 Milestar Patagonia MT
Bottom Picture: Thuren front (1.5”) and rear springs (stock height), Fox 2.0 front and rear, Fox ATS steering stabilizer, 37x13.50r18 Nitto Ridge Grappler, and a Pedal Commander. Drives like a completely different truck!
Yes there’s some rub closer to full lock that I’ll need to go in and trim, but not much.
I would like to see them redesign the Ram-Box on the inside of the bed instead so you don't lose that precious bed space.
2021 35x12.5R20 Metal Moto with Nittos. Looking for 5-6" lift if any of you have one lifted please share so I can see end result
You're better off going with a Carli or Thuren suspension leveling kit (not a puck spacer) you can fit 35's-37's with the proper back spacing, Carli and Thuren is the go to for Ram trucks if you're looking for the ultimate ride, if you're a pavement princess a lift kit is good for that.
You're not alone. I opted not to get Ramboxes because I plan on running a Softopper. I'd love to have both, but the Softopper trumped the boxes.
Personally I don't like the Ram Box myself and a Topper will be a much wiser investment for storage & security.
Changed from white to anvil...
Rubbing seems to be more of an issue but I suspect the dealer over inflated the tire to the door spec instead of tire spec.
Once you upgrade to larger aftermarket wheel/tire package that manufacturers door-decal is null & void!
Been lurking for a bit, and finally have the truck to a point where I'm not going to mess with anything until my SmartCap comes in. AEV Katlas with some take-off Nitto Ridge Grapplers in 37x12.5x17. The wife demanded I finally get PowerSteps, so...that was an easy sell ;)
*'21 Tradesman w/ PW package; wrapped in 3M Matte Military Green
Nice truck man, Are the power steps equipped in the photo?
Thanks! And no, they're not...I'll get some pics today. But, in all honesty, I could say they ARE on in those pics as there's zero difference! They tuck up behind the pinch weld. Other than a propensity to catch mud/rocks on the leading edge, they've been awesome.
