Inside LED Light Bars
B Mac
Anyone familiar with either OEM or RR, etc that makes these for a 2500?
I have feniex fusion bar in my truck. Haven’t fully wired it up yet, and also need to figure out how to reduce light splash-back.
Make sure to pick the 2010-2018 brackets not the 2019+ brackets. You may have to modify things if you have the large ACC module behind the mirror (my truck does not).
The majority of my intent for this light bar is offroad/scene lighting…light output is pretty good, but honestly not as good as I’d hoped.
Great pics and TY...look good from the inside and out
Do these lights not sit 100% flush against the inside of the window?
No the brackets are Ram specific but the main housing is a generic curve. It’s close but not a perfect seal. Lots of light splash until I find a good way to seal it. Maybe 1/4” gap. Tried a couple garage door seals but they didn’t stick well.
I’m not sure on how functional they are and can’t debate it. But those look SWEET with your LED accent headlights
This on the edge of the light shield would work id imagine
It has a bit of weatherstripping/vinyl edging like that but it doesn’t reach the windshield across the whole edge. Hard to show in a picture…
It's not an interior windshield light bar, but Headlight Revolution makes a behind the lower grill light bar I'm ging to pull the trigger on...part #448031... Safe Travels
Baja Designs does too. Probably the way I will go eventually.
Thats why this one is better it has foam on the end to fill the gaps unlike the normal edging
Gotcha, I didn’t look that close initially.
McMaster has a few options I could try out…. That bulb type you posted or maybe a “wiper” type they have ….
Thanks
Thanks
The wiper may be a bit much but would forsure work
