Looking for shocks compatible with Thuren rear spring kits, anyone try these 883-26-023 Fox Shocks, or have any idea if they will fit? The fox application guide shows they are for an older RAM2500, but they appear to have the same top and bottom attachment code as the shocks meant for 2014+ RAM 2500 (SM1,ES7, below) , as well as the travel and length specs to meet the requirements published by Thuren for their extended travel rear spring kit. Thuren obviously wants you to buy shocks through them, but they seem to have very limited options in stock. I am hoping to go with the Fox 2.5 over the 2.0, as I have run both on previous trucks and have preferred the 2.5 in terms of ride quality and robustness. The adjustability gives me some hope that I could find a setup that works well with the Thuren springs. I'm thinking of going with the stock height-mid rate springs, which I guess are supposed to be similar to power wagon.
I've dumped some information below, hard to know for sure what I am looking at, as I am still waiting for my truck to be built. Trying to get ahead and figure this out now, as many offroad parts are on substantial backorder.
From Fox application Guide: Part number | EXT length | Compresed Length | Travel | Top mount | Bottom Mount | Reservoir style
From Thuren:
Hard to tell if they will fit especially because FOX doesn't include the correct picture with the product page, the picture they show is an eyelet to eyelet piggyback shock while the specs and description clearly indicate it is a stemtop remote reservoir model:
https://www.ridefox.com/product.php?m=truck&partnumber=883-26-023
The way the pin top mount sticks through the frame makes me think a remote reservoir would be required, as the piggyback reservoir would be inside the frame rail.
From Thuren:
