HELP, alfaobd has given me a ton of errors on the dash display.
I installed the kaodtech bypass and OBDLink MX+ OBD2 Bluetooth Scanner on my 2021 2500 CTD and tried playing around with it for the first time.
The dash display is now looks like a Christmas Tree of errors.
Initially, I just wanted to first try to lower the TPMS limit to 25 psi for my new tires. I thought that was successful but apparently not. Next I tried to correct the the tire size. Thought that went OK too. I just selected the 35x12.5r18 Toyo from the drop down menu.
Lastly, I went into the trailer TPMS just to check it out. I do not have the TTPMS option nor any sensors. Again, just wanted to take a look.
I exited alfaobd, restarted the truck and a bunch of warning lights came on. Traction control, 4x4, check engine light, service trailer brake system and other errors are displayed. The display shows the 25 psi limit but all tires had over 40 psi but the numbers are still red in the display.
I tried "hard-reset" in alfaobd but that did not clear things up.
I tried disconnecting the batteries for about an hour and that did not help either.
Can anyone help me un-break my new truck?
Thank you!
