I when to a safe place and played. Really, a vast difference from what i have been used to. .. seems to be more progressive than the older gear. Pleased with what i have and dismayed at how little the dealership understands the truck.Looks like someone pointed you to an online manual in a different thread.
Trailer brake settings can be viewed/changed in the settings portion of your UConnect system.
I have needed to use "Heavy Electric" for my fifth wheel until I changed to Hydraulic disc brakes.
Was an easy change in the Uconnect (Electric over Hydraulic).
Obviously the (+) and (-) buttons work as they always have without the need to go into any settings.
Completely understand!I when to a safe place and played. Really, a vast difference from what i have been used to. .. seems to be more progressive than the older gear. Pleased with what i have and dismayed at how little the dealership understands the truck.
Thank you. I will.
Bion, i actually read the manual, made a list of questions ...then when out and played.
Another thing that gets me is the amount of info w/o any parameters. For example, water temp is 195. From my Cat, i know 220 is hot and my fan would kick in.. i am assuming this engine id the same. trsns and oil oil temp? No idea. Info w/o references is irrelivant and no mention in the manual.. or i may have missed it..
I appreciate your response.
That's really good! Mine (2018 Grand Design), likely same 7k axles as yours, was on Heavy Electric at ~ 8 since new; it still wasn't braking very well.I found Heavy Electric too aggressive for my 12K GVWR 5th. Had it low @3.0 and it was just too "grabby/jerky."
2018 Grand design 303RLS with Dexter axles and "never adjust" self adjusting brakes.
Currently running the gain on 6.0 Light Electric.
