That would certainly make me mad.This was what I had this past weekend when I had the truck out in the driveway during the hours of rain.![]()
It won't stop raining in South Central,.TX (San Antonio) either. While my dealer replaced the sunroof, that didn't resolve the problem. My truck goes back in next week for the drain tube...hopefully that'll solve the problem.Had my 19 LL in for water leaking from the roof, about 2 weeks ago. They replaced the sunroof under a campaign or recall(I don’t remember), and so far so good.…… it won’t stop raining here in SE Texas!
My A-pillar previously dripped like what's shown in a previous post. But, when I discovered the current leak, the A-pillar was already dried up. Here's more of where the water went from there. Please forgive my cheezy narration.Following up on my earlier post, my dealer replaced the drivers A-pillar drain tube...problem solved. According to the service manager, it was "kinked as hell."
EDIT: Problem not solved. We had a large storm the other day...leaked again (with the front of truck angled down)
However, just to be safe, I'm ordering a 2022, through Sandi at Mark Dodge...with no sunroof.
No, not just for the leak's sake![]()
I had a 2015 2500 MegaCab with Sunroof but no Marker Lights on top. Never wanted the sunroof, but it was otherwise what I wanted and good discount - it had been on lot for 5 months (those were the days) - anyway never opened it for 6 years and never had a leak in wet Louisiana and snow in Illinois. Made strategic error and opened it on a hot day parked in sun to see if it was cooler (Granite Grey with black interior). Next day it leaked - dripping from both sun visors and mirror. Assumed it was not fully closed and reopened / reclosed. Never knew about TSB or others but continued to leak while driving in rain. Still leaks but no longer my problem. 2022 3500 Longhorn on order without marker lights or sunroof.My A-pillar previously dripped like what's shown in a previous post. But, when I discovered the current leak, the A-pillar was already dried up. Here's more of where the water went from there. Please forgive my cheezy narration.
I had a 2015 2500 MegaCab with Sunroof but no Marker Lights on top. Never wanted the sunroof, but it was otherwise what I wanted and good discount - it had been on lot for 5 months (those were the days) - anyway never opened it for 6 years and never had a leak in wet Louisiana and snow in Illinois. Made strategic error and opened it on a hot day parked in sun to see if it was cooler (Granite Grey with black interior). Next day it leaked - dripping from both sun visors and mirror. Assumed it was not fully closed and reopened / reclosed. Never knew about TSB or others but continued to leak while driving in rain. Still leaks but no longer my problem. 2022 3500 Longhorn on order without marker lights or sunroof.View attachment 23243View attachment 23244
Hurricane Ida vs Tree - Tree lost -Ouch...Looks like this truck may have a little leak too!
What happened, blow over ??
Can you explain how you opened it up? I’m having this same issue in my brand new power wagon with a sunroof and I already sealed the cab lightsIn the A pillar where the sunroof drain comes out they have a rubber thing on the end of the drain line you can open that up to keep it from clogging my 3rd gen was the same so i opened up the drains and never had an issue again
I cut the flaps out of the drains so debris could not get clogged there anymore.Can you explain how you opened it up? I’m having this same issue in my brand new power wagon with a sunroof and I already sealed the cab lights
Were those in the top part or bottom of the drain tubes? I’ve had really crappy rainy/snowy weather the last few days so haven’t been able to really dig into it as I don’t have a garage big enough to fit the truck intoI cut the flaps out of the drains so debris could not get clogged there anymore.
I really don't think it is my drains like said in this form earlier I feel. The roof is not structured correctly and is letting way too much water at one time and it can't drain fast enough. Definitely should have been addressed by Chrysler but good luck.I cut the flaps out of the drains so debris could not get clogged there anymore.
Bottom they are in the door pillarsWere those in the top part or bottom of the drain tubes? I’ve had really crappy rainy/snowy weather the last few days so haven’t been able to really dig into it as I don’t have a garage big enough to fit the truck into
Your “thinking” is pretty much a waste of time if you are not even going to check the drains….. also Chrysler has not been around since 07 when they sold their controlling shares…. Most people have no issues so its not a roof structure issue unless your roof was not built properly.I really don't think it is my drains like said in this form earlier I feel. The roof is not structured correctly and is letting way too much water at one time and it can't drain fast enough. Definitely should have been addressed by Chrysler but good luck.
So the 1000s of people who have no issues with the sunroof don’t have this major flaw you speak of? Sounds like the dealer was just telling you what the needed to to avoid the work.I've checked the drains.. It's been back to the dealer multiple times and they even said it's a design flaw on Chrysler and that so much water comes in at one time it has no where to go. I would never by another vehicle that has a hole cut in the roof.
