6.7cummins2500
Anyone know if 2020 1500 front driver seat would fit in a 2021 2500 ?
The cab of the HD is still the old 4th Gen. The 1500 is all new, 5th Gen. Check out this thread from Ram Forums. Maybe it will answer your questions.
5th Gen Seats into a 4th Gen?
We will find out - I don't think anyone has done this yet. Well; I just bought a set of seats from a 5th Gen Crew Cab Sport...and I've got a 4th Gen Crew Sport! The fronts seem like they'll be easy enough (swap over the brackets); the back seat...well, might get interesting. Will keep...www.ramforum.com
You'd have to find out if the rails will match up. Then also if the harnesses are the same.
Cool! Sounds good. Keep us posted.
They still make the 1500 classicThe cab of the HD is still the old 4th Gen. The 1500 is all new, 5th Gen. Check out this thread from Ram Forums. Maybe it will answer your questions.
Got some pictures?Worked out great
Good to hear. Post up some pics.Worked out great![]()
Why put that seat in? Is the other one messed and u only have a 1500 seat available? Is the 1500 seat better?
Sent from my SM-G970U using Tapatalk
What about the back seat out of the 5gen 1500? Will it fit? They are reclining seats, unlike our seats in the 2500.
How did you wire them up? I only ask because I know that Ram used to run wiring and not use it (such as power heated mirrors). Did you just plug into an existing harness?
