Would you lift it?
Sawdust310
Just bought a 25 2500 tradesman, great truck so far. Picked up a fabtech 5” lift cheap, had 37” Toyo’s mounted on method wheels. Was at the dealer getting the tires mounted and I asked the service tech how they felt about warranty work on lifted trucks. He said “we’ll take care of you, but if ram asked for pictures it out of my hands”. Question is, is that a common practice for ram? His response has me second guessing my plans.
IMHO, warranty is a crap shoot. Some folks are heavily modified and their dealer does warranty work without question, some are stock as can be and the dealer/stellantis finds a reason to deny the warranty. If that’s what you want to do, then do it. I think if you don’t abuse your truck, you’ll be fine.
On the warranty issue... my truck is mostly stock and Ram asked for 2 rounds of pictures and oil records from the dealer after the grid heater nut failed. Ultimately, everything was covered, but it was quite the process. It has me debating on what future mods to make (BD Diesel Grid Heater Kit/Hamilton Flat Tappet kit) while I'm under warranty.
In your instance, larger tires could be used to void a transmission warranty etc.
That's exactly what has me concerned.
The 1st job of any warranty company is to deny a claim. That is their opening move i'm convinced in every circumstance. So if you any modifications that has the potential to making any warranty claim harder. Impossibe? No...just more hassle.
1. Is it just a lift?
2. Or does it actually change the suspension geometry and give you more suspension travel?
3. If you are lifting it for bigger tires, how much lift do you actually need for the bigger tires?
For the cost you said, I doubt it's #2.
And I bet you could get away with less lift for the tires you want to run.
Or are you just building a mall crawler?
I’m less concerned about the choice of lift, be it a thuren 2.75 or a 3.5” pin top etc and just the fact that you lifted your truck that doesn’t have the best track record on dependability. Has anyone had warranty work done where they had to send in pictures of the truck?
It’s a fairly common occurrence for Ram to request pictures from the dealer handling the warranty claim.
Got 108K miles on my PW and no issues. Been running 35s since 200 miles. But changing suspension parts may cause issues, depending on how well made they are
YMMV
YMMV
Sadly, it’s all but a foregone conclusion that a dealer would fight any claims related to suspension on a truck with a lift kit, especially one that replaces the OEM radius arms.
I had my local dealer try to tell me that the 2” level is what caused the hubs on my 2022 to fail at a paltry 55k miles.
