Wheel negative offset fitment
MWhitten207
Hi all MWhitten207 here. I've always been a Ram 1500 man until now I'm the proud owner of a 2023 Ram 2500 Laramie. I'm looking to install new wheels and tires. Looking at the fx offroad 224 black spoked with red accent 20"x 9" wheels with a -24mm negative offset and Nitto ridge grapplers 35"x 12.5"x 20". Will this setup fit on my truck without rubbing. ( I plan on installing a 2" leveling kit first). Any help would be greatly appreciated thx.20230930_174250.jpg
Did you put those wheels on? I know this is a bit old already, but that will need some trimming because you are moving your tire tread out by 78mm or roughly 3" (which is a lot)
That is incorrect, because he is also adding .5” to rim width. The outside of the wheel will be 84.5mm further out then stock, and the inside will be 71.5mm further out. I’d bet he runs on it though.
If I add 2" of wheel width only to the outside of the wheel, how much will my tire tread move out? The tread will center itself evenly between the inner and outer edges of the wheel...
