Thanks, sounds like they are doing what they’re supposed too. Any pictures installed? Curious the distance before engaging the axle compared to stock.
No pics.
They are contacting the axle statically.
Ok thank youNo pics.
What does the truck weigh empty?Hooked up the empty toyhauler with a little water in it and took it to the scales. Also first drive towing after the .5” Thuren coils and Carlo add a pack. WDH came with the trailer and only for 1k tongue weight va my 1600lb plis tongue weight. Was surprised to see it’s still transferring weight well. Curious what a WDH rated higher would do.View attachment 59379View attachment 59380View attachment 59381
The trailer has 1600lbs TW empty? That would be over 20% TW.
Typically yes, but 20% empty still seems high. I wonder what model W&P that is, none of the ones I can find have a fridge in that location but I didn’t look to hard.Wouldn't an empty Toyhauler be biased heavy in the front?
Yes I added the double battery box in the front then add weight of propane tanks and tool box with misc trailer things. It’s a W&P 21SE with the kitchen and bathroom all in the front.@Scooter29
Is this box/battery box factory? Just wondering if that's a mod you did and there's lots of extra weight there behind the propane tanks.
Thanks! I've got the 17" Method Racing 315 Wheels, CJC Edition +25 Offset. No issues with rubbing 35's. I keep toying with the idea of 37's tho...Nice rig. What wheels are you running?
If you don’t want to go so wide but you want to go taller a 285/75-18 is taller than a 35 but shorter than a 37That debate is why I split the difference with the 315/70R18's instead of going with a 17" wheel. Very few tires in that size, but since I like Open Country M/T's for their durability it was a fit. Toyo advertises them as a 36x13R18 and they are the biggest ~35 I've ever run comparing them side by side with other trucks. If I ever feel the urge to switch to a less agressive tread when these are done for I might go to a 37x12.5, but for now I like the compromise tire since they cleared pretty well stock (very minor liner rub flexed out) and won't have any problems when I get my truck back from having all my Thuren and Carli bits installed this week.
Where is the air being directed to from your hood scoop? Hopefully it's not blowing over your engine, not sure what that would do except get everything dirty.Installed the Banks CAI in today and boost tubes and cut the hood scoop open to make it functional. Though it doesn't line up with the air intake. Still like it though.
It wouldn't do anything except pull hot air from the top of the motor out through the rear of the hood. Its not gonna get any dirtier than it would now either.Where is the air being directed to from your hood scoop? Hopefully it's not blowing over your engine, not sure what that would do except get everything dirty.
