What are people using for leveling/lift kits?
I’m not saying it’s a bad kit. It’s a great kit. But, it’s not for me. I keep adding weight to my truck. I will be keeping the heavy factory springs.
i am the same i will be putting a 1" in the rear only because with the snow chief i have some extra height in the front and i want more rake for when im towing the gooseneck and 5th wheels it does not look level with minimal load
Snow Chief sits higher in the front than other Rams? I do remember reading somewhere that the spring rates up front may be different.
Yep from what i can tell my front end is about 1.5” higher than a couple friends trucks one is a gasser one is a cummins both without plow pkg and both sit lower
You only lose payload if you put the rear springs in. And the ride quality improvement is worth it to me. I can't justify spending 90k on a truck and putting a 2 inch piece of metal that costs $80 on top of my already c*ck stiff stock springs. That's just me.
These trucks ride like caddys compared to any other 3/4 ton i have owned i just went from a 1ton with over load springs i cant believe how nice of a ride this has from the factory.....
I agree 100%. At least until you hit a large bump, dip, or try to make a quick emergency lane change. The Carli Suspension on my old truck saved me a couple of times from some of the unattentive drivers here in SoCal. I was surprised a lifted truck handled better than stock.
If I was going to tow much though it would be left mostly stock suspension.
Any update on the Traxada 1" spacers? Install experience, ride quality difference, alignment, pictures, etc.
I looked at the Traxda 1" way back when I bought my '19. I'll be waiting for a report on feelings after install. I think it would be a good inexpensive option and leave my truck still level when towing. Actually can you say it sux so I can justify the Thuren setup??
I’m sure it doesn’t suck. It will ride the same, it’ll just be a hair taller than it is up front.
I just wanted to gain a little more back than what I lost with my bumper/winch and keep at least one inch of rake. This ticks those boxes perfectly.
I went with the 5.5 inch BDS, kept the standard NX shocks as ill do fox duals later on. I dont really offroad much but I enjoy the visuals of a lifted truck.
