Upper Glove Box into 2025 Ram 3500 Tradesman
Hablox
I can report to you that a 2022 ram 3500 Laramie Glovebox will physically fit, but there is about a 1/4" gap at the bottom of the box. Also, I could not find any wires for the light. May have to return to my original configuration.
Almost looks like the piece below it dips down a bit. Is it bent possibly? Or worn? Maybe that's just how it is. I'll look up what I can for that upper glovebox light.
Hopefully these can help. If you can't find this connector then you probably don't have the right instrument panel wiring harness. Could dig back further and see where the specific wires for this connector come from and run your own.
Edit: looks like the lights for the 2 glove boxes splice together in that green blob to the right of this connector in that first pic. And that repair kit (68358143AA) listed on the second pic could make this really easy to add, if it is indeed the extra wiring you need for this and you don't see the connector tucked up there somewhere.
It’s all the same as previous years. The reason for the gap is because the trim below the glovebox needs to be swapped out also. It is different than the one for non-glovebox:
Mind posting the part numbers for those of us too lazy to research it? Going to look good once that lower piece is replaced!
Glove Box From 2022 Ram 3500 Laramie
2019-2024 Dodge Ram 2500 3500 OEM Passenger Instrument Panel Bezel 6YK20TX7AA
PXL_20250612_205031827.jpgPXL_20250612_205036460.jpgPXL_20250612_205408186.jpgPXL_20250612_205415563.jpg
Mopar embossed info for passenger mid bezel:
OEM PT#35632012
YFTL#6019832
YFPT#3862109
so....just to confirm, your 2025 Tradesman truck came with NO upper glove box, so there was a huge open void? like the one on my 2025 Ram 5500.
Well, an opening with no cover. I don't know if I would call it a huge open void.
This is the first truck ever for me with no cover on the glove box.
