What is typical DEF Usage for the Cummins 2500, my usage has been a tank every 3000 miles, which seems excessive.
My 3500 gets about 7000 +/- miles a tank of DEF fluid, while a third of that is in towing.
Fuel mileage was a little disappointing as compared to other brands.DEF usage depends on multiple factors. Are you towing, how much weight are you are towing, are you in tow/haul mode, do you idle a lot, etc.
For example, if you tow a 34,000 lb trailer, you can expect to use about a gallon of DEF per 198 miles. Skip to the 13:30 mark in this video.
If you aren't towing, you may be using excessive DEF because your truck needs a software update for TSB 18-052-19.
I've noticed a decrease in def usage since I had the emissions flash done.
That's about what I get when towing a trailer. 9k trailer I am going to get about 12mpg. My DEF usage is about 3% of fuel usage. 12 mpg would mean about 400 miles per gallon of DEF..I am using 1 gallon per 438 miles. This is averaged over the last 3000miles. The dealer said they would flash the ecu. It was fine until it had its first service. I was towing a 9k trailer most of the time. Seems way over the top and it’s had the recalls.
I have about 1700 miles on the truck - a combination of relatively light towing (about 9k) and empty. I've had to put 5 gallons of DEF in so far. Rough calculation is about 340miles per gal - not too happy about that. Had been reading that it should be around 700. Truck is a July 2020 build date. Dealer says no open TSBs on it, but I'm going to check further.That's about what I get when towing a trailer. 9k trailer I am going to get about 12mpg. My DEF usage is about 3% of fuel usage. 12 mpg would mean about 400 miles per gallon of DEF..
