Please doI’d rather not out the companies that I have found on a public forum, but I’d be happy to share the two that I have talked to so far via pm.
Several scam companies yes no legit company will offer that as the 22+ ecm is still not been able to be cracked. I believe they can be bench flashed but that would involve you sending the tuner your ECM.Several companies out there offering a single tune without an ECM swap, but none of them are emissions friendly, and they do not offer transmission tuning along with it.
Between the cost for one of said tunes, and a Randy’s tuneless valve body, you’re back up there with the cost of an ECM swap.
It’s an expensive proposition either way.
The shop I have been talking with are capable of flashing the ECM in the truck, with the use of their computer/hardware that you can rent from them. Two running 2022’s with a weight loss regiment that I know of, running their tunes, in which the ECM was never removed.Several scam companies yes no legit company will offer that as the 22+ ecm is still not been able to be cracked. I believe they can be bench flashed but that would involve you sending the tuner your ECM.
They are likely doing the “bench flash” in the truck by only disconnecting the ECM and connecting their connector to do the flash.The shop I have been talking with are capable of flashing the ECM in the truck, with the use of their computer/hardware that you can rent from them. Two running 2022’s with a weight loss regiment that I know of, running their tunes, in which the ECM was never removed.
I still have the emails from my original conversation with them, I just decided not to pull the trigger since my regen issue seemed to magically knock off without much reason, and I do like having a warranty.
That makes sense to me, considering the hardware requirements.They are likely doing the “bench flash” in the truck by only disconnecting the ECM and connecting their connector to do the flash.
I need to talk to this shop. I have a 22 with 105k miles and the dealers wants over $6k to replace all my ****. I don't trust the diesel dudes kit. I'm stuckThe shop I have been talking with are capable of flashing the ECM in the truck, with the use of their computer/hardware that you can rent from them. Two running 2022’s with a weight loss regiment that I know of, running their tunes, in which the ECM was never removed.
that makes no sense nor is it accurate. Some tuners have been able to bypass the bootloader and tune the 22ECM without a bench flash others have required an ECM swap or at least send off the ECM to be benchflashed to remove the bootloader security. . Once you have access to the ECM thats all you need to be able to flash a tune. The 68RFE uses a integrated trans tune with the ECM where the Aisin has a standalone TCM and can be tuned separate.Be aware the 22+ ECU may be hacked for tuning in some shape way or form but the gearbox tuning cant and both needs doing to get the proper effect and the only way is buying a 21 unlocked ECU
So you saying the 24 ECU is cracked?that makes no sense nor is it accurate. Some tuners have been able to bypass the bootloader and tune the 22ECM without a bench flash others have required an ECM swap or at least send off the ECM to be benchflashed to remove the bootloader security. . Once you have access to the ECM thats all you need to be able to flash a tune. The 68RFE uses a integrated trans tune with the ECM where the Aisin has a standalone TCM and can be tuned separate.
No clue I have not looked that deep, some companies claim they have but I have a 19 so I did not dig deeper into itSo you saying the 24 ECU is cracked?
Yes I did as my understanding is 22,23,24 model years ECU have not been cracked yet hence buying a 21 model year unlocked ECU to do proper tuning. The tuners here in OZ go down that route, and have repaired many 22,23,24 model year transmissions because the guys that claim they can tune the 22,23,24 model year ECU’s cannot do the necessary adjustments to the transmission side of the ECU and damage the transmission's after they have tuned them, these failures dont happen instantly but within 10-20,000km depends on use, the harder it works the quicker it fails.Your post said 22+, not 24.
The point is if you can tune a 22+ ECM you have access to the same trans tuning as a 21 ECM.
This is what was explained to me if I was considering any tuning.
My apology's for any mis information it seems tuning is different in the US, so ignore my previous post or the managers can delete it.
They are likely not tuning the trans properly I would be willing to gamble its more the tune than not being able to tune properly. Plenty of 22+ trucks tuned without trans failures.Yes I did as my understanding is 22,23,24 model years ECU have not been cracked yet hence buying a 21 model year unlocked ECU to do proper tuning. The tuners here in OZ go down that route, and have repaired many 22,23,24 model year transmissions because the guys that claim they can tune the 22,23,24 model year ECU’s cannot do the necessary adjustments to the transmission side of the ECU and damage the transmission's after they have tuned them, these failures dont happen instantly but within 10-20,000km depends on use, the harder it works the quicker it fails.
Understood. ThanxThey are likely not tuning the trans properly I would be willing to gamble its more the tune than not being able to tune properly. Plenty of 22+ trucks tuned without trans failures.
