That's a Diesel tank. As mentioned above, things are much more complicated for a gas tank.TITAN FUEL TANKS 7030213
That looks to have been discontinued.Honestly I think a 15 gallon sidekick tank is probably the best way to go
I got one of these though the sidekick comes with a manual siphonSo how are people transferring gas from the sidekick to the truck tank?
Sent from me
Thanks for passing this important clarification.That's a Diesel tank. As mentioned above, things are much more complicated for a gas tank.
is there any updates on a larger replacement fuel tank for the 2500 6.4L short box crew cab?
Maybe others have this question. Where is the emissions label? Under the hood/on the hood. Also the canister, that’s under the truck, right?Help requested to keep this project moving along as quickly as possible!
I emailed with TransferFlow a few days ago and learned that they are using the 2024 Ram CC SB to design the replacement fuel tank. They need to validate any fuel system changes made to the 2019-2022 model years. (OEMs often change small details, even though they say the truck is "carry-over" from the previous model year.)
TransferFlow is looking for the following information on 2019-2022 Ram CC SB 2500/3500 (they already have the photos for the 2023 model year):
Pictures of:
· Vin Number
· Emissions Label
· OEM Tank
· OEM Emissions Canister
· Hoses (tubing between canister and tank)
If you are willing to take photos, please send them to Teri at TransferFlow. Her email is [email protected]
THANKS!
Thank you! Assumed I had it right in my mind, but wanted to be sure.On my truck, emissions label was on the underside of the hood, passenger side.
On my truck, emissions canister was "in front of" the factory gas tank, maybe 1 foot closer towards the front axle.
I wonder if this new tank will affect the slow fill ups that we are plagued with.
Slow fill ups?Thank you! Assumed I had it right in my mind, but wanted to be sure.
I’ll send some photos this week.
I've not experienced it personally, but apparently there is a known issue regarding 2019-2024 RAMs where the factory fuel tank accepts fuel VERY slowly.Slow fill ups?
I sent an email to TransferFlow regarding this issue (though it's not one I've personally experienced). In my email, I speculated that it might be the factory rollover valve causing the issue.I wonder if this new tank will affect the slow fill ups that we are plagued with.
Interesting. I didn’t have this issue on my ‘20 and my ‘23 doesn’t have it either.I've not experienced it personally, but apparently there is a known issue regarding 2019-2024 RAMs where the factory fuel tank accepts fuel VERY slowly.
Me either. Occasionally if the nozzle turns to an odd angle the pump will shut off but generally I click it on fast and wait, no problem.Interesting. I didn’t have this issue on my ‘20 and my ‘23 doesn’t have it either.
