Trailer Tow Cameras FAQ
This is intended to be a brief roll-up FAQ with links to the relevant threads related to all towing cameras.
It should also help those seeking guidance to understand what each is and what they are called.
There's an extensive thread here detailing the options:
https://hdrams.com/forum/index.php?threads/2022-ram-tow-trailer-camera-options.6626/
Recent 2023 thread (DRVM cameras changed in 2023+)
https://hdrams.com/forum/index.php?...d-how-to-order-a-config-that-will-work.12823/
DRVM Tow Mode Camera
Always on (selectable) display in DRVM
12-pin Trailer Auxiliary Camera
Radio Display that times out above 8MPH
(aftermarket box like NAViKS can override (19-24)
2019:
  • Required DIY addition of XFQ sales code kit
  • Wiring Prep Kit [82215833AB] does not include trailer camera
    • Add 82215770AB trailer single camera kit
    • Mopar or Ford sourced 12-pin Lead harness can be made to work with any analog camera
      Ford part number HC3Z-14B242-F (has lead for cam and TTPMS that can be repurposed for 2 AUX cams)
      (Ford 23-24 part PC3Z15A416A)
2020:
  • Pickup Sales code (XFQ) CC Sales code (XAC)
    • These are just the truck wiring, see cameras
  • 82215770AB trailer single camera kit
  • Dual camera kit introduced 2021 should work
2021:
New for 2022:
  • XH7- Tow mode camera (wired)- $450. You would choose this option if you already have a package/group selected that includes the digital rear view mirror.
  • AVF- Tow Mode digital rear view mirror package includes wired tow mode camera- $945. You would chose this package if you want the tow mode camera, but do not want a package/group that includes the digital rear view mirror.
  • 2022 Digital Tow Mode camera/cable kit: 68527599AA
    2023=2024 Digital camera kits are INCOMPATIBLE with 2022.
New for 2022:
  • XN1- Trailer Surround view system- $995. This is a standalone option, but you must have a package that includes regular truck surround view, and you must have a Uconnect 5 radio.
  • XFQ- Mopar trailer camera wiring with no camera- $515
SEE FULL DETAILS IN THIS THREAD POST #19, 20:https://hdrams.com/forum/index.php?threads/2022-ram-tow-trailer-camera-options.6626/
New for 2023:
DRVM 3.0
Tow mode camera kit 68586112AA (has inline repeater in kit)
index.php
index.php
2023+ kit: 68586112AA
Trailer 360° Surround View Kit - 82216421AB-001 (old PN) & 68527709AC (new PN)
Replacement Trailer to bumper Coax connector: 68532403AA
New for 2025:
Aftermarket:
With the 5th Wheel prep, there will be a 12-pin camera connector in both the bed and on the rear bumper. Only the bed is connected from the plant. If you're using the bumper connector, you will have to move the BODY cable that's behind the license plate area from the BED connector to the BUMPER connector.
Placeholder for DRVM Tow Mode Cameras
https://hdrams.com/forum/index.php?...der-a-config-that-will-work.12823/post-318281
index.php
index.php
index.php
68532403AA
(I’ll edit this post out with relevant info once this thread gets going)
2023 DRVM and tow mode camera info- basically, none of the 2021/2022 DRVM and cameras are compatible/interchangeable with 2023+ DRVM and camera parts.
Side note: If anyone has the 2023+ DRVM without side mirror cameras, and decides to add them after the fact, PM me for how to get them working with alfaobd (setting is not in the list so it needs to be done unconventionally).
I think the table format helps for the basic FAQ, Sales codes, and kit/camera part numbers if appropriate. I can add links to any DIY add-on threads once identified.
Once it's all good, it will be locked. Discussions can take place in the other threads, or members can create their own for builds.
You put great info into that one thread, but it's more specific to 22+ and we still get so many queries.
I’m in for a place holder. This should be interesting, so many different confusing tow camera options from year to year. (I’ll edit this post out with relevant info once this thread gets going)
Howdy.
Getting members PM'ing me for updated details (that I don't have).
If you wouldn't mind taking a few minutes to add details in you placeholder post, we'd sure appreciate it.
@Radiometer1
Can I use the tailgate backup camera connector for a trailer rear view camera?
Or is there a wireless OE system that fits my vehicle? I have a pre-wired mount on my 5th wheel trailer. (Which I presume is just 12 volt battery power at the mount)
2019 Laramie w/surround view.
