Trailer tire tpms
Dmclain
I have a new 2025 2500 that came with trailer tire pressure sensors. After having them installed at discount tires I followed the pairing instructions and they paired with no problems. When looking at the trailer dashboard in connect it shows zero pressure and I can’t find a trailer page in the engine cluster display. Any suggestions are welcome
Have you moved the trailer since? I believe they take movement to wake up.
I did try and it made no difference. I did a soft reset of the Uconnect and repaired the sensors and I will try moving it and see what happens. On the instrument cluster I don’t have a trailer tow screen. Looking on line it looks like I should have one but maybe they change in 2025.
Same issue. Paired them, but trailer page showed 0 psi. Deleted them, went through a new pairing, and still reads 0 psi. Just drug the trailer over 1400 miles, and still reading 0.
I found how to get trailer tire pressure to show on the instrument cluster. I have the digital cluster and there is a menu page button on the steering wheel located between the phone answer and hang up button. I was able to select the trailer page and it shows in the instrument cluster. The Uconnect (radio) screen still shows zero.
Same year and truck, same issue with mine. Cant get it to show tire pressure. I gave up. Pair, no shown psi. deleted, did it again, nothing. Screw it, will just watch in my mirrors. I have a triple axle on my boat not gona continue to let out 5 psi on all 6 then have to refill them all again. Too damn hot to be doing all that, call me lazy if you will lol
