If you are asking me, no I did not create a howto for the camera. To get from the bumper connector without buying the RAM camera which is crap, I used the Ford harness HC3Z-14B242-F $130.44 included shipping (only the first piece with the mating connector.) From there, I made my own custom camera setup using a Sony module from China and a cheap rear view camera that I gutted. The signal from the camera to the truck is NTSC video (analog), so any camera that is 12v and outputs this will work. Instead of using the RAM cables I used RG6 Siamese cable. That cable is commonly used for CCTV installations in buildings. You get the RG6 coax (which is much better at sending video than the shielded twisted pair that the RAM and Ford cables use. Because you are modifying the Ford trailer connector to account for different pinouts, a bit of soldering is required because you can't get just the pins. Erich Jaeger is the OEM for Ford, and I have tried and tried to source from them. They really are playing hardball in keeping this out of the hands of competition. They have an exclusive agreement with Ford, even though the connector system has an ISO designation. RAM uses the same connector, but is made for them by another manufacturer in Mexico. You can't get that one either.Have you made a howto on your custom trailer camera cable? Don't think I've seen it.
