Trail_Wagon
Its a tight fit, that tire goes way further up than you think it would at full flex, especially when disconnected. I had to make my resi mounts twice becuase the first time I didn't get them high enough, or inboard enough.. The mounts are super simple... I just cut the bottom of the fox mount off, then welded that to a small piece of 1.5" angle iron. I tapered the edges for asthetics. I tucked things as far back as I could and had to cut the inner liner to make room for the reservoirs.Anymore information and close up shots you can provide of the custom mount you fabbed for the resis? I just got my front shocks delivered on Saturday. Was looking at the instructions and the mounts provided. I am running the 75th anniversary factory wheels with 37x13.5 nitto mud grapplers. My concern is at full flex or even before hitting full flex, that the tire may rub or hit the resi especially with the high offset factory wheels I have.
If you have time to share some close ups and details on that mount you fabbed up, I'd greatly appreciate it. I'm trying to figure out exactly how and where I'm going to mount the resis up front before I even dive into the install. For now, they're just sitting in my garage waiting for install.
One VERY important thing to note is I bled the nitrogen from the shocks so I could loosen the fittings on the hose and position them where I wanted. You will never force the fittings or hose into an angle it doesn't want to go in without bleeding the pressure first. I have to tools to recharge so it was no big deal, but if you don't have that capability, you might just want to use the fox stuff.
