You’d have to do some hose extending, but if you find this location doesn’t work out for you, on the Gladiator Mojave they mounted the front reservoirs up behind the front bumper to make sure there was plenty of space in the wheel well.I finally got a chance to pull the springs and bump stops, and fully flex the suspension. As we had feared, the tire would contact the reservoir at full flex. So I cut the mount off, moved it up 2 inches, inboard 2 inches, and back about 1/2 inch. Now I can fully flex without hitting the reservoir.
Its theoretically possible for the tire to rub on the hose at the absolute limits of travel, But the wheels would have to be fully turned, the suspension fully flexed and the bump stop completely compressed into the cup. Its possible to smash the bump stop into the cup, but it takes a lot of inertia. The Jounce bumper can easily hold the weight of the entire truck at static load. In reality, its nearly impossible to replicate a full turn lock, full flex, and then a suspension hit hard enough to compress the jounce bumper completely into the cup, all at the same time. Even if I somehow did, it would only just touch the hose. I'm good with that.
edit: that should have been front bumper, not rear.
