elephantrider
Hydraulic Lifter Crew
| I currently believe these to be the correct part numbers. The last part instrument panel bezel 6VQ511AHAA is the part with the AC vents (I do not think I need that part but not sure). I am hoping someone can confirm before I place the order. |
If you're adding the nav 4c, then you will need it.
Center Stack
Product ID: 68370124AB
Remove$185.32 × Quantity
$185.32Multi Media Radio
Product ID: 68428584AC
Remove$741.28 × Quantity
$741.28Instrument Panel Bezel
Product ID: 6VQ511AHAA
Remove$227.13 × Quantity
$227.13Continue Shopping Empty Cart I currently believe these to be the correct part numbers. The last part instrument panel bezel 6VQ511AHAA is the part with the AC vents (I do not think I need that part but not sure). I am hoping someone can confirm before I place the order.
See posts 20 and 26. You either need the center stack dash piece, or you’ll have to modify the new radio bezel to fit.So far this is what I came up with based on my current center stack can anyone verify? My truck did come with sxm, no navigation. Do I need the portion with the A/C vents?View attachment 12572
I believe this is not the nav radio 68428584AC. Can you confirm?If you're adding the nav 4c, then you will need it.
Sent from my Moto Z (2) using Tapatalk
Thank you2019 Ram 2500 Tradesman Crew Cab 6.4L Hemi V8 4WD Radio. Multi media - 68428584AC | Factory Chrysler Parts, Bartow FL
Radio. Multi media. 2019 Ram 2500 Tradesman Crew Cab 6.4L Hemi V8 4WD. Genuine Ram Part - 68428584AC. Ships from Factory Chrysler Parts, Bartow FLwww.factorychryslerparts.com
It appears to be without nav, this is a site I've found which actually contains done description on the parts.
The infotainment kit for this upgrade does not show it as including the vent bezel. So you should be all set.
Ahh. I found the older video and it looks like they used to use all factory parts but now they have a radio bezel that's been modified by them in some way to work with the 5" center stack.You might continue to look into this and maybe make a call to infotainment and ask for clarification if I was you. I’m not sure the radio itself has anything to do with it. It’s the mating of the bezel and the center stack. I looked at doing this mod for a long time before I actually did it. Infotainment used to show the video of them sending you the whole kit, radio, center stack and bezel. I agree now it doesn’t yet the price hasn’t changed either. So I’m not sure what changed on their side.
So, my information may not be correct. Some modification may be needed to the 5" center stack vent bezel for it to be used for the 8.4. Some pictures would be nice because these factory parts are hard to find good pictures of onlineThank you
That’s nice of them but it would have been nice for them to lower the price since they no longer send you the extra $200 plus bezel. It’s the same as it was with it. There site did say expect shipping delays as well. I ordered from moparfactoryparts.com and had it at my door in 9 days ground shipping.So, my information may not be correct. Some modification may be needed to the 5" center stack vent bezel for it to be used for the 8.4. Some pictures would be nice because these factory parts are hard to find good pictures of online
Do you happen to have the part number for the support bracket that goes behind the radio?Also there is a plastic backing plate that sits behind the radio and supports it. The new radio is larger. I made it work by elongating the mounting holes but I will see if I can identify a part number for that.
Is the part number you supplied (5YU433XLAF) the one for the upgraded bezel with the marbled finish?i did upgrade my a/c bezel to a nicer model with aluminum trim and some grey squirly crap on top...lovin' it.View attachment 10447
Did your order the part numbers that Jackmup put out there? Do you have any pics of your install?That’s nice of them but it would have been nice for them to lower the price since they no longer send you the extra $200 plus bezel. It’s the same as it was with it. There site did say expect shipping delays as well. I ordered from moparfactoryparts.com and had it at my door in 9 days ground shipping.
Yes it is, I also upgraded door panels black with marbled trim. Have those numbers as well.Is the part number you supplied (5YU433XLAF) the one for the upgraded bezel with the marbled finish?
No I don't have that number I modified mine. But I suggest ordering it with everything else. Need parts counter help with that one I could not figure out which one on line. Shipping takes so long I needed to modify on the fly. That part can't cost too much.Do you happen to have the part number for the support bracket that goes behind the radio?
