Tradesman Fog Lights
a tradesman would definitely need the factory bracket. there is nothing behind the blank.
does baja specifically call out 2019 availability?
Yes. Go to their website. They have a section specifically for 2019 HD Ram stuff.
FYI I had a set of their Squadron Sports in amber wide cornering on my 2014 and they were amazing in the fog and for lighting in the ditches. I had a set of Squadron Pros in clear spot and also incredible.
those are damn nice.
I'm using these h11 connectors and this switch to get them wired up. should be easy peasy.
$237 but I bought an extra set of bezels and brackets in case I broke something on the 1st go around, so closer to $190 minus the extras.
When you do finally get them installed and working I would appreciate if you let us know how you did it. I have a Tradesman and would love to install fog lights as I do not think the headlights are bright enough.
elephantrider - read through your posts on the Cummins forum. Thanks a lot! I’ve got my bezels and lights just waiting on the brackets.
I got the bezels from MoparPartsGiant $25, the brackets from Mopar Factory Parts $28 and the lights from eBay for $80 for the pair.
I used this switch and mounted it in this location.20191224_194636.jpg20191225_101126.jpg
then it's just a matter of grounding everything, getting wire loom on the wires. I also made the crossover harness, like this.20191223_144557.jpg
Elephantrider, does your truck have the auxiliary switch panel? Wondering if I will be able to hook those up to one of those switches in the factory Aux panel.
mine didn't but there's a guy over on cumminsforum who did. you just need the pin out but it was easier just to wire it direct.
yup, here ya go - these are specific to the tradesman. the upper level trims have a different lens
and bezel. this does NOT include any wiring harness, plug, etc... i need to take a peek and see
what's under the bumper next wknd, to see what else may be added. if all else fails, i'll just run
these on an in cab switch.
fog assy - 68353533AA - need "2"
tradesman bezels - 68449341AA - comes in a set, so need "1"
bracket kit - 68449383AA - comes in a set, so need "1"
thanks!
