Towing a Boat
ChrisC
I’m picking up a new boat weighing about 5000lbs tomorrow. Should I be hitting that button on my panel that says Tow/Haul when towing? I have a 2018 Laramie 2500 Cummins. Ty
Do you have to? Will it hurt the truck if you don’t? - no.
That being said, I’m in a similar position as you, and I use tow haul mode and the exhaust brake to mainly save on brake pads. Let the engine/transmission do what they were designed to do.
Thanks Burton. That answer is good enough for me. I bought this truck new knowing one day I’d have the boat of my dreams and now that the day has come, I just wanted to do things right. I’ve always used the exhaust brake and found it saves me on braking.
7K with tow-haul on.
7
I only run tow haul if the teuck constantly is searching for a gear, then I'll run it. 5K isn't much but the tow haul just changes shift points.
Sent from my SM-G986U using Tapatalk
Flat towing I don’t run TH. Trips up to Vegas or higher elevation areas I will run TH. I tow 5k lbs with my Hemi 6.4.
