yes that is odd. I have the 8.4 but mine lists selectable fill alert as standard equipment.
Yes, not listed on my window sticker. I wonder if anyone with the 12" screen has it. Thank you Jadmt for the assist!!
There is a TSB for this feature not working properly on our trucks. I also found another TSB on the Jeep forum since many of them were complaining about it missing. I will drop by the dealer when I have time to see if they can flash the feature in.
My 12" has it. Truck is a Laramie.
Have done this multiple times. Will go out of app and back in and it’s saved as my new thresholds but still shows low pressure indicator on gauge. Then if I turn truck off and back on it randomly resets back to 65psi all around in the ATF. It makes no sense. I swear it worked fine for like a week straight as well then suddenly this.You have to delete the old presets. Try that. There is a button to access the presets
It is not listed on my window sticker either, @AnthonyD1978
but, I have it on my 2019 w/ 8.4”
Seems to be no rhyme or reason
There must have been an over the air update. My tire fill assist was de-selected and Greyed out. I re-enabled it and it was set to 65.Have done this multiple times. Will go out of app and back in and it’s saved as my new thresholds but still shows low pressure indicator on gauge. Then if I turn truck off and back on it randomly resets back to 65psi all around in the ATF. It makes no sense. I swear it worked fine for like a week straight as well then suddenly this.
I hate to say it, but hallelujah! At least I know I’m not going crazy. All I’ve heard on the forum is how this works and I can’t wrap my head around why it isn’t. I too think something changed. Let’s you adjust thresholds still but not lower than the 65psi minimum.There must have been an over the air update. My tire fill assist was de-selected and Greyed out. I re-enabled it and it was set to 65.
I was able to put mine back down to 45 and save itI hate to say it, but hallelujah! At least I know I’m not going crazy. All I’ve heard on the forum is how this works and I can’t wrap my head around why it isn’t. I too think something changed. Let’s you adjust thresholds still but not lower than the 65psi minimum.
That's the way mine has always behaved. I got my TPMS settings changed through AlfaOBD so it's moot now.There must have been an over the air update. My tire fill assist was de-selected and Greyed out. I re-enabled it and it was set to 65.
I think mine may have had the same issue. I didn't really give it much of a chance though, as I updated mine through AlfaOBD a day or two later.I hate to say it, but hallelujah! At least I know I’m not going crazy. All I’ve heard on the forum is how this works and I can’t wrap my head around why it isn’t. I too think something changed. Let’s you adjust thresholds still but not lower than the 65psi minimum.
Got a procal snap as well. Waiting for it to arrive.I need to permanently fix mine with my procal snap but I haven’t had a tpms warning yet so I haven’t bothered
For now....I was able to put mine back down to 45 and save it
Hi Anthony, we would be happy to confirm whether your truck is equipped with this option - feel free to send over a private message with your VIN. Thank you!I don't even have the TFA as an option on my truck. Not listed in any of my Uconnect settings. According to the manual it's an "if equipped" option. What option on the truck gives you TFA? My truck is fully loaded. Maybe power wagons don't get it?? @RamCares
And the mystery deepens. Mine has a 4/22/2019 build date and the 12" screen. Maybe that's the "winning" combo.
That is for 2013-2017 Rams, because the rf hub needs to be reset for the new pressures to take. This is not the case for 2019+ HDs.I found this at the AEV website. "Please note: A visit to your local Ram Dealership and use of the WiTech diagnostic tool is required to complete this procedure. Although your TPMS screen will show the new values, it will not “take” and stop blinking until your dealership completes the process." Is this true?
