JScan. Adaptations > radio frequency hub settings > rfh pin readingAnyone here pull a code? Dealer isn’t close by
Now where does the code goJScan. Adaptations > radio frequency hub settings > rfh pin reading
Procedure right below pin reading- rf hub replace procedure.Now where does the code go
Where did you hook up the ALFAODB under the dash?As people have mentioned, you could go the route of AlfaODB or you can get an AEV Pro-Cal Snap.
I just used the Pro-Cal Snap about a couple hours before me posting this. It's super easy to install and use. I changed my tire pressure warning from the stock 60/65 to 40 psi. I also calibrated my speedometer with the help of a GPS speedometer app and driving around after each time I programmed it. Highly recommend it.
You plug in a bluetooth dongle (like OBDlink MX) into the OBD port. The alfaobd software goes on your phone or tablet, which you then connect to the dongle via bluetooth. On 19 and above trucks you need a bypass cable to get around the SGM and write to a module. (You can read, clear codes, ect without that).Where did you hook up the ALFAODB under the dash?
YepYou plug in a bluetooth dongle (like OBDlink MX) into the OBD port. The alfaobd software goes on your phone or tablet, which you then connect to the dongle via bluetooth. On 19 and above trucks you need a bypass cable to get around the SGM and write to a module. (You can read, clear codes, ect without that).
