Tire Pressure Sensors
Anyone here pull a code? Dealer isn’t close by
As people have mentioned, you could go the route of AlfaODB or you can get an AEV Pro-Cal Snap.
I just used the Pro-Cal Snap about a couple hours before me posting this. It's super easy to install and use. I changed my tire pressure warning from the stock 60/65 to 40 psi. I also calibrated my speedometer with the help of a GPS speedometer app and driving around after each time I programmed it. Highly recommend it.
Where did you hook up the ALFAODB under the dash?
You plug in a bluetooth dongle (like OBDlink MX) into the OBD port. The alfaobd software goes on your phone or tablet, which you then connect to the dongle via bluetooth. On 19 and above trucks you need a bypass cable to get around the SGM and write to a module. (You can read, clear codes, ect without that).
Yep
Or if you’re an Apple user JScan will do it too.
I just got a 23 Power wagon made 6/23 and purchased an AEV pro cal snap to reset the TPMS and speedo. There is no place to plug in the bypass harness to the OBD unless I remove 2 brown wires from the port. All ports are being used. I have a call in to AEV and waiting on a reply.
2023 Powerwagon equipment level 2 and towing package.
