I have a 2020 3500 Crew Cab. When I purchased the truck a year ago, I found a great deal on some Anniversary Power Wagon wheels that were takeoffs before it left the showroom floor. The problem is the factory tires for that setup is Goodyear Wrangler DuraTracs in a 'D' rated tire. However, when I lookup the specs and compare against the 'E' rated tire, I see they have the same Max Load capacity (3195 lbs). The only difference I can find is the Max Inflation Pressure is 65 psi versus 80 psi. We are looking to upgrade our travel trailer to a larger 5th wheel and I am concerned these tires might be underrated for the job. I also don't want to run out an buy new tires since these are still like new. I appreciate any feedback you may have. Thanks!
