Throttle lag
Norwood
When entering a expressway if I nail it to merge into traffic my truck lags a second or two before responding, kinda scary
Their are abut 3 ways to mitigate that . Most expensive to least . Getting a tuner , Installing a Pedal Monster or like device (which I use )or try rolling onto the throttle instead of mashing it .
I learned to roll onto the throttle instead of mashing it. It surprised me the first time it happened. Even though it seems like a long time when it happens, it is probably less than a second. Once she spools up she goes however.
Thanks I will try that. Another question, what is the gear select switch on the steering, and could you give me a example of when I would use it?
Thats to limit your truck to a max gear like if you are towing heavy and want it to not shift to 6th for some reason then you would use it or when i am towing on some of the local winding hilly backroads i will limit my truck to 3rd gear so its not constantly shifting from 3-4 as i go up and down the hills
Been thinking about a pedal monster. Is it worth it and what’s the main advantage. I use my truck 99% of the time for towing my boat or 5er.
I got rid of mine. Didn’t want to deal with pulling it out for any dealer visits. There is an initial feel that it is nice but you get used to it and forget it is there. Just roll your throttle faster, same thing.
The pedal monster, and all other similar devices are just an amplifier for the pedal signal. For example, say you’re pushing the pedal 5% down the truck thinks you’re pushing it down at 10%. They don’t speed anything up or reduce any lag.
You don't have to remove it when you go to the dealer, look into it and read there is no way it voids any warranty, and if you wanted to remove it it's just 2 plugs. Like jsalbre said all it does is make your throttle pedal more sensitive and there is a high, medium, and low setting. I like mine on the medium setting, it just eliminates that slight pause when you mash the pedal to get up and go.
Takes only a couple of minutes to remove and when you reinstall it remembers so you don't have to reprogram it . When I tow I just put it back to stock . I put it on the top setting on once in a while just for fun and it will launch your truck in a hurry ! I usually keep it on city about halfway up the scale which is easier to driven stop and go traffic . No throttle rolling will get you moving as quick as the top setting. Just fun like half the crap we spend money on for our trucks .
We shouldn't need aftermarket everything when it comes to throttle response. This isn't a new problem. Sluggish on occasion is an understatement. Big motor with questionable balls.
Just a suggestion, plan your merge maneuvering so it is not last second. We've all been caught with an unexpected need to accelerate quickly, but routinely going WOT to match traffic speed is kind of dangerous.
Or if you need instant acceleration, get a Tesla, not a 3.5 ton truck.
I’d highly recommend the tune. I had the exact same problem and ended up with Calibrated Power. Emission intact shift on the fly tunes. Night and day on every aspect of my truck. Throttle response is just the beginning. There are different tunes depending on what you’re doing with your truck. I toggle between ‘modified’ street and ‘light tow’. Modified street optimizes throttle response and gear changes. These trucks were built to help meet EPA guidelines and that’s why a lot of the performance gets programmed out. I was towing prior to having this, and was afraid to pass anyone. The throttle response was horrible and it would not kick down fast enough to have any confidence. All of that is fixed with this tune.
My 22 DRW HO is not a problem at all on acceleration. I don’t get what everybody’s talking about. My 2019 2500 felt a little less.
