The Other Vehicle
I need to know all the specs on whatever this is.......... and more pictures!
We took a lawn tractor, took the front axle off, stuck a bunch of scrap steel off the front(old steel pallets, fence post pipe, etc.) to stretch the frame, built a picnic table frame on top, bolted some wood to it, extended the steering arm, and dropped a big ol' exhaust tip on it.
In progress:
Finished:
Sorry, I don't have too many pictures. It's great fun, only problem is you really can't talk to the riders people while driving it.
In progress:
Finished:
Sounds like the solution is to electrify it. Plenty of room for batteries and a big electric motor on that thing!
That's a good idea! I might do that. It would probably be on a different chassis though, this one is a janky, high schooler, learning to weld edition
I've seen some built onto the frame of a golf cart, that would be a good base to electrify.
I would have to keep the exhaust tip tho.
In progress:
Finished:
Ya gotta roool through a drive through with that baby ………instant pick-a-nick.:cool:
Hook a speaker up to the “exhaust” and play Ferrari noises.
Replaced seals and changed shim stacks on Fox coilovers this past weekend. My supervisor kept his eye on me to do it right. Seems intimidating at first but actually a pretty fun and relaxing process.
View attachment 61408View attachment 61409
Rig looks awesome. Always fun getting the shocks dialed in. I assume you’re not doing much rock crawling in Florida so shoot me a message when you come north Alabama/ Tennessee etc.
This is something I have not yet done, rebuild a shock. Very cool.
It’s fun and you’re not limited to just swapping the valve shim stacks you can get creative.
I drilled bleed ports in the pistons of my 2.5”s in addition to swapping the stack of .010”s for .008”s and .012”s for .010”s. Normally I would put bleed shims in but i knew it needed more bleed and i didn’t have the correct three port piston bleed shims in my parts bin so I just put them in the drill press and made bleed ports. Custom tuning at its finest.
You can run them by 4wp or somewhere to get them filled with nitrogen if you don’t have access to fill them with 200psi nitrogen.
They have a bunch of service tools but you can get by with a cheap adjustable pin spanner. You want a good clamp setup to hold the shock body and shaft. The rest of the stuff is optional. The bullets cover the threads to help with o-ring installation. Calipers are handy since valve shims aren’t labeled
Very, very cool. It's a matter of time for me before I dive into this.
I completely changed the shim stacks from what I ordered 10 years ago for the previous crawler. Now I have heavy compression stack and light rebound stack. I'm fortunate to have a friend that has a lot of knowledge in valving. He guided me to a good starting point but I may have to take them apart a few times to dial in compression/rebound perfectly. Before you dive into research how you want to change valving so you're in the ballpark to begin with.
I'll play...
the DD: 2003 BMW 525i 5-speed, M-sport package (as seen on Regular car reviews :
The Jeep: 1970/1972 CJ5, Amc 304 V8, 3-speed, Tera-low gears in the t-case, full-ish cage, locked rear, front disk conversion, 33" tires.
Dirty Bike: 2001 XR400r street titled (and my kid's 03 xr100)
And the streebike I bought on an impulse and almost never ride: 2020 V-stom 650
