Terrible Towing pics thread
I see those trains running South between Denver and Mexico often.
Didn’t know where to post this. If you have Instagram this was posted by stealthperformanceproducts
5C80A9B7-2D1D-4D3C-A534-BC693ED3D509.jpeg908D19EF-8FB1-4D66-BD38-548F10DA007B.jpegAE0234C9-791F-409B-99E1-F6DF200D0759.jpeg
Looks like there’s about 5’ of cargo boxes sticking out behind that bumper. Some basic understanding of leverage and practical physics really needs to be a requirement for any kind of towing or hauling.
Couldn't tell if it's a 2500 or 3500 but the frame is the same. From the top of my head it should be able to tow around 16k lbs conventional trailer and that is quite a bit of tongue weight behind the rear axle.
Unless those cargo boxes are filled with led I don't think they were a big deal. But we will never know without more info
To add, looking again at the last picture, there appears to be some old rust where the crack developed. As well as a different shine on paint a few inches away from the crack which could indicate some welding been done in that general area and the frame's been repainted.
As brutal said its the fault of the weld. The crappy weld created a fracture point, this is the exact reason you will NEVER see a factory frame weld go straight down the frame they will go at an angle or have a step/ gap between welds its simple metallurgy. It also looks like stick weld which is another issue on its own for the thin frame material
