Tailgates
Subtle is fine, and I like it's OEM and mounting holes are already there, would be nice if plug was there for plug n play setup! Will add to list, trailer TPMS just ordered, have the modules and cable, so that project is next.
Unfortunately, the wiring isn't already there for the SRW.
Tap off license plate or running lights. I used a Curt 7-pin to 5-flat Y adapter to pick up the power from the trailer running lights instead of the truck as I also intend to use that adapter to pick up reverse for my backup light setup. I'd like to avoid tapping the truck wiring and it also makes it a but more "portable" if I ever need to move it to a new truck.
Tapped into the right license plate LED, cut off the factory plug and installed a weather sealed plug connector, light is a nice addition without being overwhelming.
