Tailgate height
CdnHO
South Ontario and South Texas
Planning an ordering a 26 Dually. Can I impose on someone with a 26 Dually diesel and rear air suspension to measure the height of the open tailgate? From the top of the tailgate (open) at the center to the ground. Parked on level ground. Thanks gang.
I can maybe get someone to measure for you later today - but my guess its going to the same as your 2021.
My 2021 is a rear wheel drive. I heard newer trucks were a bit lower allowing me to order a 4X .. I have an older fifth wheel which is already nose high when towed. So using tail gate height as a common measurement. I would prefer to order a four-wheel-drive, but not if it is significantly higher for the fifth wheel.
I am being told its 38 inches.( give or take an inch or two because I am not seeing it LOL)
The specs that I can find don't seem to differentiate between 4x and RWD in terms of tailgate height. However when I bought my 2021 there was a diffference. Thought I would try to find some real world numbers.
