Tailgate height
CdnHO
South Ontario and South Texas
Planning an ordering a 26 Dually. Can I impose on someone with a 26 Dually diesel and rear air suspension to measure the height of the open tailgate? From the top of the tailgate (open) at the center to the ground. Parked on level ground. Thanks gang.
I can maybe get someone to measure for you later today - but my guess its going to the same as your 2021.
My 2021 is a rear wheel drive. I heard newer trucks were a bit lower allowing me to order a 4X .. I have an older fifth wheel which is already nose high when towed. So using tail gate height as a common measurement. I would prefer to order a four-wheel-drive, but not if it is significantly higher for the fifth wheel.
