Suspension bushings
Crusty old shellback
So I have a 2021 Power Wagon.
I now have 110K miles on it.
I was runnin the Thuren tuned Fox shocks. After about 30K plus miles, I started getting the rocking boat effect.
If you've read my build thread, you know what I went thru trying to rebuild them.
So I replaced them with a set of Bilstein 5100 series shocks and that seemed to fix the problem for the most part.
I finally got the Fox shocks rebuilt and installed them. Only difference is I used 7wt oil vice 5 wt that was in them originally. Maybe a little difference, but didn't think it would make much of a difference.
So after several trips to town with the rebuilt shocks, I have the rocking boat effect again, a little worse than before.
So wondering if maybe the suspension arm bushings might be wore out? If so, how do I check?
Or could it just be the valveing shims in the shocks are wore out?
Gonna order some 5 wt oil and was thinking of ordering the shims too.
Getting ready for a road trip next week, so gonna put the Bilstein shocks back in for the trip .
Got a reply back from Thuren.
Like me, they say the thicker oil should stiffen up the shocks some.
They are as miffed as I am as to why it rocks.
When I get back from my trip, and it warms up, I'll do a close inspection of the bushings. Also thinking of ordering new shim stacks as well.
So doing more research today, one thing that came up was sway bar end link bushings. So need to look at those. That actually makes more sense since it's body roll.
Same issue with the Bilsteins installed? You typically get a little clunk when SB end links go bad. Factory sways?
Bilstein was better, but still had sway. Factory swaybar and links.
I heard some loud clunking in the front one time when off road. Just figured it was the front end bottoming out
Put the rear of the truck on jack stands under the frame. Took off the wheels and let the axle go to full drop.
Swaybar. Ends look ok. There is a little flex in the bar when I push on the ends. Normal?
Looked at the radius arm bushings. Lower arm has a little cracking in the rubber, but not bad.
Couldn't find anything loose. Swapped the Bilstein shocks back in the rear. Fox are still on in front.
Pushing down on both shocks at the same time, the Fox are stiffer. But they worked fine for 30K plus miles.
Going to town tomorrow so will see if there is any difference.
Saturday, I'm going thru the front end.
Just looked under the front end real quick. All seems normal.
Drive around the property with the front saw bar disconnected. Flexed the suspension real good over some big dirt mounds.
Nothing seemed out of the ordinary.
Can someone reading this please do me a favor.
Go to your rear swaybar and push on the end link and see if your bar flexes. Mine bows a little in the middle and the end flexes toward the center of the truck.
Thanks.
One thing to consider is when the bushings in hose new arms wear out in a few years will their bushings be available?
My brother has a Wrangler 2006 or with a lift kit on it and now the bushings are worn out and it’s a little hard to find replacements bushings.
