Speedo Recal Suggestions
So we need the mx+ and cable but why alpha obd AlfaOBD if mx+ comes with an app??
For those of you that use AlphaOBD AlfaOBD on a 2022 Truck....(Or 2021 even) Will it work if I follow this?
This guy makes it look pretty easy, but he has an older truck and I am not sure if my AlphaOBD AlfaOBD will give me the option for a 2022....Which one will I use if it doesn't offer the 2022 trucks? Anyone know for sure? Thanks fellas! Love my new truck and I am having Carli Suspension put on it on Monday and tires and wheels on Tuesday....Merry Christmas and thank you in advance!
Yep, thats the one I learned from. Just a few minor differences in the displays, but easy to figure out. Just make sure you do everything in the video, including at the end on clearing the faults.
Worked with Body Computer MY2022 PowerNet & ABS Bosch/Continental/Teves/TRW Powernet MY2019+ PowerNet for my 2022 PW
Does anyone recommend a tablet with gps for the alfaodb? GPS so I can run mapping software. Android tablets looks to vary a lot in quality and features.
This is exactly what I did, used 2642.00 mm for my 315/70/17 tire size with the MT Baja A/T's on stock wheels. Also, use the how-to seen below to be able to clear everything out.(obviously choose the newest year listed and adapt to this how to)
Looking for some help. This is the first time using AlphODB, when I select my body module and connect I don’t get past this screen (see attached). Am I missing something.
Next step?
What are you trying to do? Status/Faults to read the system ID so you have it, then Active Diagnostics and Car Configuration Change if you're trying to make a change.
So I figured it out. I have to click on the “open hood”. But when I try to change the tire size I get this
