jerad
I just wanted to share my experience this past weekend putting my 2500 gasser payload to the test.
I started a new project around the house. Putting in retaining wall and using Allen block. Went to the local builder supply and loaded up! According to Allanblock, the main blocks are 75lb a peice (30ct). The caps if memory serves me correct are around 50lbs (10ct) and the corner block 55lbs (6ct.)
So my load I estimate was a little over 3000lbs not including myself, skid, etc..
The truck handled the load pretty good but the height of the load made the truck wiggle a bit going down the road. I don't know if the wooden skid it was on was flexing and causing a bit of wobble or the height or both.
Suspension was about and inch off the bump stops.
My rated payload on my door is 2937 which I exceed based on my calculations. My trip was short, only a few miles.
I wouldn't want to go far with the load but I think if it was loaded a little better it would improve the experience.
