Rubber window weather strip solution
Don’t mess with them, I did and it made things worse. I tried to ignore the issue but people kept asking WTH..
I finally replaced them with cheap Zon/Bay, I forget which, hoping that the materials might be different than factory.
I haven’t noticed the new doing anything but the truck doesn’t leave the garage much this time of year.
The replacement felt more plastic and less rubbery…meh.
I loosened the rear screw and adjusted mine a bit, they sit more level now.
A couple of questions for you.
Are they rubber like the OEM?
How hard to remove and replace?
They are very similar to the oem ones. Only took maybe 10 or 15 minutes to swap them all out. Once i figured out the best way to release the first one, the others went fast.
