Hey Matt, Can you give an example of "better fuel"? Are we talking name brand stuff like Chevron?
I guess I should’ve explained better huh? “Better fuel” is kinda vague isn’t it? Sorry.
So long story short, I was having weird regeneration issues. Regenerating more frequently, soot load returning within ten miles of a regen finishing, etc etc.
I used to fuel up at Sheetz religiously but a few weeks ago, needed fuel and couldn’t get to a Sheetz. Stopped at a local BP and bought a tank of their fuel. (Coincidentally didn’t have any Hotshots EDT with me so that tank didn’t get any additive). Drove the truck the next day and instantly noticed the truck was running “better”. Felt stronger, smoother, more responsive etc. Noticed almost immediately that my passive regeneration was occurring on the highway more readily, whereas before it seemed like I had to drive for hours to see any passive regen.
Fast forward, I’m on my fourth tank of the BP fuel and the truck is in every way performing better.
Passive regeneration happens readily at highway speeds. Soot load stays low, burns out easily, and doesn’t return quickly, truck is stronger, runs smoother, has more noticeable power and responsiveness.
What’s different about the fuel? I have no idea.
All I can tell you is the BP fuel was about .20-30¢ more per gallon over Sheetz. I’m assuming there’s a difference in cetane level, % of biodiesel, maybe additives? Etc. Etc.
I honestly can’t tell you what fuel is better, but I guess my recommendation would be to try different fuel stations (maybe ones with higher turnover rates on their bulk tanks, and ones charging more money?). Pay attention to your soot load / DPF gauge.
Things to look for:
1. At 75mph on the highway, do you see evidence that passive regeneration is reducing the soot level? Keeping in mind this isn’t always an instantaneous thing. Sometimes it takes 20-30 minutes of constant driving, and you won’t see the gauge move, but on subsequent trips does the level lower some?
2. When the truck goes into regeneration, at highway speed (70-75mph) the cycle should finish at roughly 20-25 minutes and your gauge should be back at zero percent.
3. Pay attention to how rapidly soot load returns post-regen cycle. For example: prior to the fuel change and elimination of additive, I was seeing soot register back on the gauge anywhere from 12-40 miles after finishing a regen. Now with the new fuel and no additive, it usually takes me 200-300 miles before I see soot register, and within a few drive cycles on the highway I’m back to zero again. Level rises some, then goes back down. To me this is the way it should work. Keep in mind I’m daily driving my 22 3500 DRW HO and it’s 100% unloaded and no towing. Nothing I’m referring to included any towing.
4. How far can you go between regen cycles (hours and miles)
